Integration works as it should, put under configuration.yaml. And unplugging either of my WAN ports, it updates within 1 minute as it should.
But there is no indication within Home Assistant that it is actually functional. It does not add anything to the integrations page, when trying to add the integration it says it can’t be configured in the UI.
There should be:
- An integration Tab named as the FQDN as configured in Yaml
- Entity Showing the current IP, with history statistics.
