A quick search reveals multiple Google Drive back up add ons. Which one to choose? Are any of them going to be official add ons at a point in time?
I’ve been using
for about a month.
The UI, setting options, performance and support are great. Easy to install, setup and problem free so far. I haven’t evaluated any of the other Google Drive add-ons.
I have been using the add-on below for a few months and it has been flawless.
That being said I was planning on checking out sabeechen’s add-on today. It seems to have the same functionality with a really polished interface. Ill report back after some run-time.
The one @gbealmer posted definitely seems to be the way to go if you’re just starting out and want something that’s an all-in-one setup. I’m using the same one as @silvrr since I already had it setup and it’s working well for me. But it takes a little more work to set up because you have to do some additional work yourself to create an automation.
Thanks for all your replies. I installed sabeechen add on and it works fine so far very easy to set up indeed.
Addon from sabeechen is super polished, very nice user experience. It should be added to Community Hass.io Add-ons or Home Assistant Community Store!
