Anyone have an addon for this? I used ddclient to run it on my Ubuntu server build but in hassio it doesn’t let me install anything even with the developer mode enabled where I can see the whole file system.
I am trying to do the same thing, did you figure this out ?
Interested as well. Any luck achieving this?
I’m also interested in this. There’s a Google Domain’s component:
But in my situation I have multiple domains I need updated; from what I can tell you can only setup one
Edit: This is where I ended up
configuration.yaml:
rest_command:
domain1:
url: https://user:[email protected]/nic/update?hostname=domain1.com
domain2:
url: https://user:[email protected]/nic/update?hostname=domain2.com
automations.yaml
- id: 'uniqueid'
alias: Update Domains
- platform: time
minutes: '/5'
seconds: 00
condition: []
- service: rest_command.domain1
- service: rest_command.domain2
Other than the above example from jayoungers (which I couldn’t get to work), anyone get multiple domains to work with built in google dns updater -
https://www.home-assistant.io/integrations/google_domains
@dheat I followed the example from @jayoungers and it worked
In my configuration.yaml I have:
rest_command: !include restcommands.yaml
In restcommands.yaml I have:
domain1:
url: https://USER:[email protected]/nic/update?hostname=DOMAIN.NAME.GOOGLE
The automation looks like this:
- id: Update Google DNS
alias: Update Google DNS
description: ''
- platform: homeassistant
event: start
- platform: time_pattern
minutes: /5
condition: []
mode: single
hi, am i right, does the integration update the public ip address on google domains?
