Is there a Google equivalent to the Alexa Media Player Custom Component’s “sensor.last_alexa” template sensor?
Specifically, my goal is to get different actions & TTS responses depending on which room I am in when I give a command. IE: “Hey Google, goodnight” from my room will use TTS to respond “goodnight, Shadowpheonix” but from my roommate’s room will respond “goodnight, roommate”, and will also turn off all lights in the appropriate room.
I have successfully done the TTS and lights using different triggers for each room, but that results in some rather verbose trigger commands when you have multiple automations for every room in the house.
Regards,
Shadowpheonix
