Google Home and ALexa together?
I have both, and now it gets confusing since one accept certain commands and the other others.
Would like to make it more uniform.
Is it possible now to have GH and Echo both in emulated hue, or any workaround?
Probably not helpful but my workaround is Ha-Bridge.
emulated hue for Echo
and
Ha-bridge for GH?
Is it possible to use emulated hue for Echo (mine works very well) while using ha-bridge only for Goggle Home?
I don’t know sorry, but you could try it!
I use Ha-Bridge for both. When I was first setting up Echo I had problems getting hass to boot when emulated hue was enabled. I have been meaning to try it again but I haven’t gotten around to it yet.
when?
I installed not too long ago, to me is a very stable component.
My problem is that would like to control switch, script, and yeelight light with Google Home as I do with Alexa.
A few months ago - not sure exactly but whenever the new dot II came out.
I don’t have yeelight but I do use switch and script. It’s the scripts with customised dimmer and off commands I have in Ha-Bridge that make it a bit more work to try emulated hue again, plus the Home and Alexa both on the same network.
I know people were running both Ha_Bridge and emulated_hue at the same time back then but not sure if it is more complicated now with the home needing port 80.
having problems with it. Have ths error
Request Error, Pleae look in your habridge log: error {“type”:6,“address”:“/lights/1”,“description”:“Error on calling url to change device state”,“parameter”:“/lights/1state”}
