Greetings everyone… I’m still fairly new to HA, so please go easy on me… I’m plenty technical, however.
TLDR: Google Assistant disregards the current state of my garage door and just toggles it whenever I ask for it to close or open my garage.
I have a couple of ESP32 Sonoff SV’s. I mostly followed Dr Zzz’s 3rd gen garage door video
I configured it as a device class: garage in ESP yaml (see below), and it seems to work fine in HA.
One issue I’m having is that in Google Home… while it sees it come in as Device type: Garage via Home Assistant, and it knows if the garage is closed or open when I ask it verbally, “Is left garage open?”, it responds with “Left Garage is closed”, which it is. But if I then say “close LEFT garage” to Google, it says “one or more devices isn’t available, you might want to try setting them up again”. I previously had a Ewelink/CoolKit WiFi garage door controllers that were cloud enabled and connected into Google Assistant directly (I think) and/or maybe through SmartThings. I did my best at disconnecting that integration; but who knows, maybe I missed something?? I know this isn’t a Google Assistant specific forum, but do you know how I might troubleshoot that “one or more devices isn’t available” thing? I definitely see my Home Assistant’s “left garage” (and “right garage”) device in the Google Home app in my “garage” room.
Pics showing the devices in the Google Home app in Garage “room”.
Google Home app shows this on the device, which seems to indicate the current state of the door based on which button is highlighted.
My second issue, is if I tell Google via voice to “Close Garage”, which is a “room” that the left garage and right garage devices are in, then both garage doors “toggle”… if they were closed, they then open. If they were open, then they close.
If I ask google to “open garage” it will ask me for my pin for the left garage, which I have set as “device_class: garage”. My “right garage” currently does NOT have that setting, so the “PIN” is not currently asked for. But I plan to update it once I finish testing. Telling it my pin will allow the garage to open just fine. But again, it only “toggles” the state… It doesn’t seem to pay attention to whether the door is already closed or not. That is my main concern here.
My esphome yaml:
esphome:
friendly_name: Left Garage
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "removed"
ota:
password: "removed"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Left-Garage Fallback Hotspot"
password: "removed"
captive_portal:
- platform: ultrasonic
trigger_pin: GPIO05
echo_pin: GPIO04
update_interval: 60s
filters:
filter_out: nan
timeout: 9m
switch:
- platform: gpio
pin: GPIO12
name: "Garage Door Open Switch"
internal: true
inverted: False
- platform: restart
binary_sensor:
device_class: presence
lambda: |-
if (id(ultrasonic_sensor1).state < 1.5) {
// car is in the garage
return true;
} else {
// no car
return false;
- platform: gpio
internal: true
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: False
device_class: garage_door
filters:
- invert:
cover:
lambda: |-
if (id(closed_stop).state) {
return cover::COVER_CLOSED;
} else {
return cover::COVER_OPEN;
restore_mode: NO_RESTORE
open_action:
# Turn the OPEN switch on briefly
- switch.turn_on: door_switch
- delay: 0.3s
- switch.turn_off: door_switch
close_action:
- delay: 0.3s
stop_action:
- delay: 0.3s
optimistic: true
What else can I provide to help paint the picture, here?
Thank you so much!
-Hildebrau
