Hi folks. I’ve got Home Assistant OS (v5.9) running on an Intel NUC 10. Home Assistant Supervisor is version 2021.1.0. Connected to the NUC I have a Texas Instruments CC26X2R1 with Z-Stack coordinator (CC26X2R1_20201026) firmware on it. I’m running the Zigbee Home Automation integration with 62 devices and 115 entities. On the integrations page, the integration says " XDS110 (03.00.00.13) Embed with CMSIS-DAP, s/n: L1100F06 - Texas Instruments". I have the Nabu Casa cloud running and use this to connect to Google Assistant. There are 9 Google devices (home, mini and display) scattered around the house.
I’ve recently changed over from Zigbee2Mqtt to ZHA and set everything up again. For the most part I have the entities that I wish to expose to Google Assistant in groups and I expose the groups domain. This was the way I had it done in Z2M and it has worked fine for both. A handful of light groups and a temperature sensor are exposed to Google too.
An issue that I have run into recently is with the larger groups after moving to ZHA. For example, if I say “Hey Google, turn on living light” it works quickly and successfully but “Hey Google, turn on inside lights” then it will take about 6 seconds and then say “sorry, something went wrong for the inside lights”. I have noticed that turning on/off a group with 3 or less devices in it seems to work perfectly however the larger groups cause the failure response from Google. Despite Google’s apologies, the lights generally turn to the state I asked for, it is just an issue of an undesirable Google response.
After playing with this for a few days, I think the issue might be a timeout setting. Unlike Zigbee2Mqtt in some ways, ZHA is more ‘integrated’ so HA can likely see that all of the switches/lights are still being transitioned 6 seconds (or so) after the command is issued so the state is probably ‘in progress’ or something like that. Maybe it finishes switching the devices after 8 seconds but Google has timed out by then and plays the undesirable response.
What do you guys think the issue is and, more importantly, how do I fix it? I really can’t live with the response from Google as it erodes confidence in the my home automation ecosystem which I take much pride in. Thanks in advance.
