I am new to home automation but keen to get deeper into the details.
Context: The totality of my home installation is several Google Home speakers and a pair of Sonoff Basic one channel wifi switches connected to lamps. The link between Google Home and the switches is via IFTTT. I have defined some phrases in IFTTT to turn the lights on/off.
Complication: It works ok but because, I assume, IFTTT doesn’t present devices natively to Google Home, my phrase has to be, shall we say, a little cryptic. If I try to use something like “Turn on the front room light”, the Google Home speaker responds with “It doesn’t look like that device is connected”.
Question: Can I use Home Assistant to present an arbitrary device natively to Google Home such that if i ask ‘turn on the lights in the front room’ I have complete control of that action that is taken?**
I haven’t done anything clever with the switches (eg, installing tasmota), but I have worked out how to trigger them via curl (using ifttt webhooks). It isn’t a particularly elegant solution but I figure if I can pursade Google Home think I have a light (or whatever) and to run a command (curl) when asked, I can pretty much do anything.
I’d really appreciate any advice.
Thanks,
STDOUbT
