Hello guys!
I know there are a lot of topics about it, but i’ve implemented all tips and it still doesn’t work, i lost days and nights trying to fix this
My HA is runing on VirtualBox machine, i’ve a local IP 192.168.15.201 for it (fixed on router by the MAC address).
DuckDNS with following config:
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: DUCK_DNS_TOKEN
domains:
- EXTERNAL_URL.duckdns.org
seconds: 300
NGINX with the config:
domain: EXTERNAL_URL.duckdns.org
hsts: max-age=31536000; includeSubDomains
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
DNSMask with the config:
defaults:
- 8.8.8.8
- 8.8.4.4
forwards: []
hosts:
- host: EXTERNAL_URL.duckdns.org
ip: 192.168.15.201
My configuration.yaml
default_config:
logger:
system_log:
max_entries: 100
http:
base_url: https://EXTERNAL_URL.duckdns.org
tts:
- platform: google_translate
#base_url: http://192.168.15.201:8123
My openned ports on router:
I can access my HA by http://192.168.15.201:8123 or https://EXTERNAL_URL.duckdns.org both works great, i can control the Google Home Mini, play music or mp3 audio link (using Service > media_player.play_media)
But if i try to use the service tts.google_translate_say I always get the error Error on init TTS: No TTS from google_translate
On my logs, when start the server:
INFO (SyncWorker_3) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
INFO (MainThread) [homeassistant.setup] Setting up tts
DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=google_translate_say>
When i try to use the service tts.google_translate_say:
ERROR (MainThread) [homeassistant.components.google_translate.tts] Timeout for google speech
ERROR (MainThread) [homeassistant.components.tts] Error on init TTS: No TTS from google_translate for 'hello'
Anybody can help me ??
