Hi all,
I am new here and I am looking for some support regarding my network configuration.
I have configured HA to be accessible externally via DuckDNS + LetsEncrypt. I also had to configure Dnsmasq to have the same internal and external URL. After that, I configured my router to use my raspberry PI where HA is running to be the primary DNS for all DHCP clients.
So far so good, all is working fine.
But I have the following issue now: It seems that my Google Home / Nest Hub devices have troubles accessing e.g. TTS results or the lovelace dashboards.
Example:
I am trying to get a Google Home Mini to say something via TTS. I call the service, send the message and hear the “bling” on my Google Home Mini but I don’t hear the actual message.
When I check the states in the dev tools, I see the following media_content_id on my Google Home Mini: https://[myhostname].duckdns.org:[myport]/api/tts_proxy/a715f46d41e2149a4ec4f2c0772ef5254222dd83_en_-_google_translate.mp3
So I guess what happens is the following:
The Google Home Hub Mini tries to access the MP3 file
Since it is going to [myhostname].duckdns.org via DNSmasq it points to https://[mylocalip]:[myport]
Google Home Hub Mini then refuses to access the MP3 file, because it is a local IP with a self signed certificate.
Do you agree that this could be the case?
If yes, any ideas on how it could be resolved?
Thanks all!
