I am having some trouble in the last step of home assistant wiki when trying to setup google home with HA.
I am in this last step:
Click the + sign, and near the bottom, you should have [test] your app name listed under ‘Add new.’ Selecting that should lead you to a browser to login your Home Assistant instance, then redirect back to a screen where you can set rooms for your devices or nicknames for your devices.
When I click that button to link my google action it says liked successfully but then it doesn’t prompt me the devices, and when clicking again the + button is seems not to be linked
Do you know if having ssl auto signed was working fine?
I was just trying with the following:
http:
ssl_certificate: /root/.homeassistant/certificate.pem
ssl_key: /root/.homeassistant/privkey.pem
in HA config with certificates being auto signed
And when I tried with reverse apache proxy with SSL autosigned also it tells me this other when trying to add it to home app:
https://prnt.sc/ngfu1s
So might think if SSL could be the problem.
Kind regards
Do you have entities exposed?
Do we know if self signed SSL certificates are not gonna work with google or alexa?
Could that be the problem?
Kind regards
I have finally added signed SSL certificate with let’s encrypt, and when I am redirected to login home assistant page from the app, it prompts me with the following error:
I also have a reverse apache proxy for this, and when being redirected from google home app and having that error, I am getting also this in my logs:
2019-04-25 00:38:03 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py”, line 275, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File “aiohttp/_http_parser.pyx”, line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
2019-04-25 00:38:05 ERROR (MainThread) [aiohttp.server] Error handling request
Does anyone know why it is not working?
Kind regards
Hello Guys,
No worries, it seems it is solved now
Kind regards
