Hi all,
I have just installed Nginx with the video by burnsha and works great now got sub domains for server and addons etc but since doing that google home doesn’t respond correctly, where I used to say activate room temperature and google home used to say activating room temperature and run the script now you say the same phrase and google replies activating 2 scenes but then just activates the script same with switches say turn on stair light GH replies turning on 2 switches then just turns on the stair light.
It was working correctly when I had my hassio set up with the Nginx add on but couldn’t work out how to setup a sub domain for my other servers with the addon
Any ideas I did have to amend the google actions to the new domain ,I used the domain https://xxx.xxxxxxx.duckdns.org. Before I swapped from the nginx addon to the nginx docker I just used domain https://****.duckdns.org and it worked fine. The actual scripts and switches are working it is just the replies that are wrong? I’m not using the hassio cloud just the manual setup
this is doing my head in , Just stopped the docker version of nginx and restarted the addon version and everything is back to working as it should, I think I’ll just carry on using the addon version, Does anyone know how to add a subdomain to the addon version of nginx without getting a certificate error?
