pi@raspberrypi:~ $ sudo setcap 'cap_net_bind_service=+ep' /srv/homeassistant/homeassistant_venv/bin/python3
Failed to set capabilities on file `/srv/homeassistant/homeassistant_venv/bin/python3' (Invalid argument)
The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
I am guessing, I need to change the path, but am not sure of the correct path. Any thoughts?
Hi, thanks for your response.
The ip in the config is the hass.io’s ip address.
Apparently in hass.io there is a problem with google home and aiotp server.
I tried on hass io and hassbian without any success for now.
Will look more in to it later.
