First of all, thank you so much for this! Works pretty much right out of the box.
I’m trying to add this to a wall control panel, and I’m using Card-mod to control the height of different cards so everything is aligned and nothing flows off the bottom of the screen. I’ve done the same for this, and it works to resize the card but the text itself flows offscreen. Is there a way to get a scroll bar inside the card, or just cut off any extra text?
Secondly, an alpha value of 0 is apparently not supported. 0.1 is almost invisible so that works, but it’s a little wonky. Trying to input 0 has the same effect as 1.
I am new to HA. I have it running on a RPI3B I believe I need to install the gkeepapi but I get a command not found when I run pip install gkeepapi. I installed from HACS Thanks for any help.
I guess that’s where I get confused. I setup an integration to my hubitat and didn’t have to edit the config.yaml. Can you point me to what I need to do? Thank you
I have the entity finally, I installed the card using the manual setup. How do I assign the card to that entity in a dashoard. The card doesn’t show up anywhere that I can find
Situation here is similar. Some cards are shown in UI editor, some are not. You just have to configure it using yaml card editor (available on the bottom of the card chooser)
Making some progress. I added your post to the raw configuration and still couldn’t get a card. I selected a manual card for the entity when adding to the dashboard, entered your post and it didn’t complain but it says there are no notes. There are 3, so I might be close
