Google map of devices on Main user interface
I was surfing the web about Home assistant one evening and came across instruction on how to setup a map of your devices (using itunes as device tracker) on the main user interface perhaps in one of the groups. Now I can’t find out how that is done.
Any idea how to do this.
I’m not sure if this is what you are talking about, but if you use the icloud component, then if you click on the map link at the left side of the screen, it will show you a map of where your devices last reported. I’m not aware of a way to do this using itunes.
Yes, I know I can do that. What I want to do is imbed a map on the main screen using the grouping.
I was just looking through my bookmarks the other day and re-found this. I set it up two days ago and it’s working great.
@fabaff can I use this to display more than one device on the same map ?
