I tried creating /config/custom_components/device_tracker/google_maps.py and
/config/custom_components/device_tracker/locationsharinglib.py using latest 2.0.2
Also tried downgrading to 0.67 as some suggested on the other thread.
deleting the cookie on each reboot.
No joy…
GPS location only updates at reboot or restart.
018-05-26 21:47:37 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform google_maps
File “/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/init.py”, line 184, in async_setup_platform
disc_info)
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/device_tracker/google_maps.py”, line 38, in setup_scanner
scanner = GoogleMapsScanner(hass, config, see)
File “/config/custom_components/device_tracker/google_maps.py”, line 53, in init
self.max_gps_accuracy = config[CONF_MAX_GPS_ACCURACY]
KeyError: ‘max_gps_accuracy’
Response: [[[[‘105378156597123040953’, ‘https://lh6.googleusercontent.com/-7U9rDgvbJ5M/AAAAAAAAAAI/AAAAAAAAAAA/AIcfdXB-GN4akAInz5H4vNQkKsaRu5lSvA/mo/photo.jpg’, None, ‘Tracked User’, None, None, None, ‘0ahUKEwiKorbMy6jbAhVr2IMKHeQuDygQvDgIAygA’], None, None, None, ‘0ahUKEwiKorbMy6jbAhVr2IMKHeQuDygQu4IBCAIoAA’, None, [‘105378156597123040953’, ‘https://lh6.googleusercontent.com/-7U9rDgvbJ5M/AAAAAAAAAAI/AAAAAAAAAAA/AIcfdXB-GN4akAInz5H4vNQkKsaRu5lSvA/mo/photo.jpg’, ‘Tracked User’, ‘name’], 0]], None, ‘0ahUKEwiKorbMy6jbAhVr2IMKHeQuDygQ8ZABCAE’, ‘lQ4MW8qDMuuwjwTk3bzAAg’, None, None, ‘CLSdsNgFEAAaJQAigwZCvn1avSyWmdcwkdeI7GWbn5KdHbw8rkAzOtsNrXMBPQA=’, 30, 1527516822166, None, None, [1, None, None, 1]]
File “/config/deps/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py”, line 292, in get_shared_people
people = [Person(info) for info in output[0]]
File “/config/deps/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py”, line 87, in init
self._populate(data)
File “/config/deps/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py”, line 95, in _populate
self._latitude = data[1][1][2]
TypeError: ‘NoneType’ object is not subscriptable
make sure only these 2 files are in the /config/deps/lib/python3.6/site-packages/locationsharinglib/
/config/deps/lib/python3.6/site-packages/locationsharinglib/locationsharinglibexceptions.py
I was in the middle of the post on the other thread, so I finished it and then found you leading me here.
I did read this before posting mine. That is why I hack mine to 2.07. Maybe that is what fixed mine plus rechecking. I going to link back to my post in case someone else gets this far. Thanks for your help. https://community.home-assistant.io/t/google-maps-entities-not-showing-up-confusion/54687/8?u=penright
Thank you! I was having the same issue since .68 update. I followed your instructions and everything is working now. I manually created new versions of those .py files and pasted in the raw code from github. Maybe there’s an easier way to do it??
version number is in the /config/deps/lib/python3.6/site-packages/locationsharinglib/ folder, file name is .VERSION
I Have the same issue - cant get the google maps location sharing running.
How do I get this into my hassio installation (0.70.1)? I have no access to the files, even when I log on via ssh…
If I now comment them out, they dont get recreated. Nor do they get any updates if they are not commented out.
The logs say nothing about this problem
If I log into google maps manually I can see all users as expected.
I also tried to remove the local .google_maps_location_sharing.cookies file and did endless restarts. If I delete and restart I get the following message only:
2018-06-05 15:33:25 ERROR (SyncWorker_14) [locationsharinglib.Service] Could not open pickle file, either file does not exist or no read access.
Keep in mind, I am new and just got mine working.
The error message I was getting after I deleted the cookies file also. I think it throws that message anytime the file is not there, even if it is expected not to be there. I think it is more info and should not be called an error. The error is, if the you can not log on either with or without cookie. Once I had the version changed, again not sure if that is what fixed it or not, delete the cookie, and still could not log on. I checked the google account I was using, in your case “!secret google_username” and see if you need to approve the device. I too have approved it before and going back to check, found I needed to do it again. In fact, in hindsight, I bet it has to be approved anytime the cookie file is deleted. As part of troubleshooting for a different issue, I cleared my cookies. I had to re-approved the device again.
I downloaded the locationsharinglib.py and locationsharinglibexceptions.py and saved them to /config/deps/lib/python3.6/site-packages/locationsharinglib
I downloaded the newest version of google_maps.py from github. The file already contained the :
updated REQUIREMENTS = [‘locationsharinglib==2.0.7.’]
part. I deleted cookie and restarted. But nothing changed, it does not work. I dont even get error messages.
Luke, using a browser, have you logged on as the sharing user and looked at its logged on attempts yet?
In the screenshot you can see where it was blocked. Then you can see when I figured it out the next day and allowed it.
What does the first line translate to? To me it looks like fault something …
That don’t sound right, mine reported linux. What is your OS?
Also, once I got the “New Linux signed in”, I never see it update, even on reboots. I think it has to do with the cookie. That is why, I am guessing, that once I had my code/configurations correct, I had to delete the cookie one more time, then approve the log in one more time. Then reboot one more time.
