Google Maps Tracking is failing after some time always
I have activated the google maps tracking feature. But the service is failing always after some time and I have to restart the home assistant. I am using newest Hassio System:
2018-06-02 12:39:14 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 99, in _populate
self._latitude = data[1][1][2]
TypeError: 'NoneType' object is not subscriptable
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/google_maps.py", line 67, in _update_info
for person in self.service.get_all_people():
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 393, in get_all_people
people = self.get_shared_people() + [self.get_authenticated_person()]
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 361, in get_shared_people
people = [Person(info) for info in output[0]]
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 361, in <listcomp>
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 91, in __init__
self._populate(data)
  File "/usr/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 107, in _populate
raise InvalidData
locationsharinglib.locationsharinglibexceptions.InvalidData
Now even a restart does not solve this problem. I dont get any updates any longer. Any idea? I am not even getting error messages now. The .google…cookie file is still created when I delete and restart the system.
Found a solution yet? Have the same error message now. It worked for a month and update broke it.
Here is my error message, if someone can help :
Error setting up platform google_maps
  File "/srv/homeassistant/lib/python3.5/site-packages/locationsharinglib/locationsharinglib.py", line 109, in _populate
    self._charging = data[13][0]
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 184, in async_setup_platform
    disc_info)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/google_maps.py", line 46, in setup_scanner
    scanner = GoogleMapsScanner(hass, config, see)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/google_maps.py", line 66, in __init__
    self._update_info()
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/google_maps.py", line 78, in _update_info
  File "/srv/homeassistant/lib/python3.5/site-packages/locationsharinglib/locationsharinglib.py", line 459, in get_all_people
  File "/srv/homeassistant/lib/python3.5/site-packages/locationsharinglib/locationsharinglib.py", line 451, in get_authenticated_person
    None,
  File "/srv/homeassistant/lib/python3.5/site-packages/locationsharinglib/locationsharinglib.py", line 95, in __init__
  File "/srv/homeassistant/lib/python3.5/site-packages/locationsharinglib/locationsharinglib.py", line 113, in _populate
    raise InvalidData
I have problems with my cookie file expiring every so often, and have to recreate manually, here is the thread with the info in it,
Cookie file is newly generated and filled with credentials as I can see.
I found that just deleting the component and re-installing it didn’t work, the only way to get it to work was to manual run the command as in the post I linked too. I find I have to do it about every 3/4 weeks.
Solution for me
  1. Deleted, then installed location sharing lib in virtual enviroment
    pip install --upgrade locationsharinglib
  2. Manually upgraded the google maps lib from the author
    srv\homeassistant\lib\python3.5\site-packages\homeassistant\components\device_tracker\google_maps.py
  3. Edited google_maps.py and overwrite the password section to my password and username.
  4. Deleted cookies file from .homeassistant
    .google_maps_location_sharing.cookies
And restarted HA (deleting cookie file was not enough, had to upgrade everything to the same version)
the problem is with the function that returns all people,
it returns shared people + authenticated person:
the problem with that is the authenticated person returns None at array index [13] which fails it,
to fix it updated google_maps.py to use get_shared_people instead of get_all_people
