I am trying to make make a window in which I can choose origin, destination and travel mode to get an estimated travel time.
I have been able to do the following:
Input_select to make variables where I store the origin, destination and mode with a user friendly name.
Template sensors where I convert the user friendly name to a string that can be used with Google Maps Travel Time.
I have two issues:
- The sensors work fine with origin and destination. However, when I use the same method to try to set mode (under options) I get errors when checking the configuration:
Invalid config for [sensor.google_travel_time]: value is not allowed for dictionary value @ data[‘options’][‘mode’]. Got ‘sensor.resa_mode’. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.google_travel_time/
I do not understand why it does not work for mode when it works for origin and destination. Is there some other way that I can do this? Can the sensor.resa_mode be converted to a string?
The relevant code is:
In input_select.yaml:
resa_mode:
options:
- 'Bil'
- 'Kollektivt'
- 'Cykel'
- 'Till fots'
initial: 'Bil'
In sensors.yaml:
sensors:
resa_mode:
value_template: >
{% if states.input_select.resa_mode.state == 'Bil' %}
driving
{% elif states.input_select.resa_mode.state == 'Till fots' %}
walking
{% elif states.input_select.resa_mode.state == 'Cykel' %}
bicycling
{% elif states.input_select.resa_mode.state == 'Kollektivt' %}
transit
{% endif %}
And finally also in sensors.yaml:
- platform: google_travel_time
api_key: !secret google_travel_time_api
origin: sensor.resa_start
destination: sensor.resa_end
options:
mode: sensor.resa_mode
Solved 2. When I use the input select to change destination the input is changed and the corresponding sensor is changed, but the destination in the travel time sensor is not changed. A possible reason may be that it does not update due to the scan interval. Is there a way to force the travel time sensor to update if the state of the destination sensor is changed?
Any help is appreciated!
