I used the Google Maps travel time integration with pleasure via the config file. I was able to set a scan interval there. It now moved to GUI integration and I cannot find the option anymore to set a scan interval. Is it now fixed for every 5 minutes? Because this is way too much for me. I don’t want to update at all at some hours.
I’m wondering the same. I just got a billing alert last night for the first time. Opened up the console and it seems that updating to the GUI has tripled the number of calls in a day I make. Which means I’m going to have to remove the integration for a while as I can’t afford to keep paying.
Seriously guys, so we start integrating configuration.yaml integrations like ‘Google maps travel time’ into the GUI to make things easier while destroying basic functionality like ‘scan_interval’ in the same move? Why?!
This topic should be closed as it has already been fixed with an update. Integration polling can be turned off, which also works as a solution. An update schedule can be set via the update_entity service call.
