The Hassio addon has a limitation that any cast commands are ignored, however this docker container works great: Google Assistant Webserver in a Docker container
I made it work in 0.90. Your folder setting is correct. But you should also update the switch.py
Great news! Iām way behind on my updates, but I like the new Stream update (would like to see unifi though), but I canāt lose my precious google music!
@MomoB Could you show me your relevant config?
My switch.py: https://hastebin.com/osadalejuq.py
My media_players.yaml: https://hastebin.com/oxejikerev.cs
I am still getting an error in home assistant:
Unable to find platform gmusic.
Thank you for the hint.
Got it working and it behaves perfect for this usecase.
I can successfully call my playlists.
Now I need to think about how I want do the mapping between the RFID cards and the playlist.
I could simply use the same service and just do a curl to the specific playlist.
Will hopefully have time tomorrow for testing.
Your files are similar to mine, only difference is that i did not put my credidential in !secret
But did you also copied the __pycache__
file that was in the previous custom_components/media_player
folder ?
Iām my homeassistant/custom_components/gmusic
i have
__pycache__
__init__.py
switch.py
Confusing.
The pycache folder should not be important in that case. There is only python bytecode which is created after the first start normally.
Is your configuration available at github or something?
I need to commit my latest changes and would like to have a look to a working config.
@claytonjn Thanks again for the hint.
I think I will go this route:
I have setup Google Assistant Webserver in a Docker container.
I then can create my notify service:
notify:
- name: ga_broadcast
platform: rest
resource: !secret google_assistant_webserver_broadcast_message
- name: ga_command
platform: rest
resource: !secret google_assistant_webserver_command
Now I can create automation to use these commands:
The reset playlist automation will always get the input_text to back to āBootValueā.
For every playlist I would have an automation.
input_text:
playlist:
initial: BootValue
automations:
- alias: Reset playlist value
initial_state: True
- entity_id: input_text.playlist
platform: state
- service: input_text.set_value
data_template:
value: "BootValue"
- alias: Play linkin park
initial_state: True
- platform: state
to: '0011205436'
- service: notify.ga_command
message: "Play the playlist LinkinParkMeteora on uberall"
- alias: Play Motivation
initial_state: True
- platform: state
to: '0016042153'
message: "Play the playlist Motivation on uberall"
This works so war via the home assistant webinterface.
Now I try to figure out how to pass only the RFIF Card ID to the home assistant input_text.
I know how to do this via curl, but I do not know how I get the RFID Card ID from the reader right now.
Hopefully I can figure that out.
Great work!
You can use my code to grab the RFID cards from the reader to do the curl command.
Iām trying to reset mine back up after all the HA updates and sifting through this thread.
I got mine playing again, but they are always playing shuffled. lol
I figured it outā¦ smhā¦
I have 2 components, one is gmusic and one is gmusic_shuffle. By default the gmusic.py listed in the original post shuffles the songs. I renamed that to gmusic_shuffle and then commented out a line to play track after track in a duplicated gmusic. At the bottom of gmusic.py (now switch.py) I commented out this line.
# random.shuffle(self._tracks)
Now my albums play straight through.
Phew!
Actually i was using your setup before 0.89.0 thanks a lot for the inspiration!
I wanted to just remove the parts I do not need anymore, like the cardList.csv.
So that the logic is only in home assistant and the rasperry pi is only sending the tag to home assistant.
Great Idea! Please post back if you get that working. Iād love to check that out and possibly make the switch as well!
I am just struggeling to understand how I would get the card ID.
I can get some basic ipython3 terminal running and I can listen in a loop to get some card information:
Import librarys and setting up the reader:
import evdev
devices = [evdev.InputDevice(path) for path in evdev.list_devices()]
for device in devices:
... print(device.path, device.name, device.phys)
device = evdev.InputDevice('/dev/input/event0')
Looping until the card will be near the RFID reader:
for event in device.read_loop():
...: ... if event.type == evdev.ecodes.EV_KEY:
...: ... print(evdev.categorize(event))
...: ... # pressing 'a' and holding 'space'
Result when card is near the reader:
key event at 1553636173.066585, 11 (KEY_0), down
key event at 1553636173.074576, 11 (KEY_0), up
key event at 1553636173.082591, 11 (KEY_0), down
key event at 1553636173.090593, 11 (KEY_0), up
key event at 1553636173.090593, 2 (KEY_1), down
key event at 1553636173.098581, 2 (KEY_1), up
key event at 1553636173.106586, 2 (KEY_1), down
key event at 1553636173.114597, 2 (KEY_1), up
key event at 1553636173.114597, 4 (KEY_3), down
key event at 1553636173.122592, 4 (KEY_3), up
key event at 1553636173.122592, 5 (KEY_4), down
key event at 1553636173.130603, 5 (KEY_4), up
key event at 1553636173.130603, 4 (KEY_3), down
key event at 1553636173.138604, 4 (KEY_3), up
key event at 1553636173.138604, 11 (KEY_0), down
key event at 1553636173.146608, 11 (KEY_0), up
key event at 1553636173.146608, 7 (KEY_6), down
key event at 1553636173.154604, 7 (KEY_6), up
key event at 1553636173.154604, 4 (KEY_3), down
key event at 1553636173.162608, 4 (KEY_3), up
key event at 1553636173.162608, 28 (KEY_ENTER), down
key event at 1553636173.170609, 28 (KEY_ENTER), up
I am not sure how to convert that into the card ID.
I think I still do not understand the code in your repository.
EDIT:
Got it working.
Need to document this the next days!
Ok, it kind of works.
So the problem is, when you crate a voice command to a google assistant you can not play a palylist.
There is no official way of that doing that right now.
You can for sure play an album are some genre music, but not a playlist:
https://support.google.com/googlehome/answer/7211943?hl=en
That means this could be quite difficult to solve.
Thank you for all useful informations in this thread. Got mine working fine and am compiling all those entities in a simpler card (see screenshot below). Iām then asking myself if thereās any way to get GMusic song metadatas as I got it working with radio streams, any idea?
Iām able to use voice commands to play a playlist (e.g. āShuffle my Thumbs Up playlist on All Speakersā) however I do have Google Play Music/YouTube Premium.
I do have a google play music subscription too.
Could you create a playlist with random songs and just try to say āok google, play playlist WHATEVERā?
In my case this does not work reliable.
If there is some way of doing that reliable it would be awesome!
Interesting, your right - it only works with Thumbs Up. Thatās the only playlist I every play so Iāve never tried anything else.
Does your Thumbs Up playlist work for you? Iām my case the only thing unique about that playlist is that itās downloaded to my phone. I canāt imagine that would make a difference though, it using Google Assistant to play it works from Assistant speakers and gawebserver, completely independent from my phone.
@claytonjn could you post the switch.py and _init.py? Iām not sure what needs to be done to make the component work again
Sorry for the confusion, Iām not using this component because I only care about playing my auto-generated āthumbs upā playlist which I could never get working. Iām using the gawebserver docker container to accomplish this.
