Google Nest and Separate Reverse Proxy Network
I was finally successful in getting Home Assistant functioning on my Reverse Proxie’s separate Docker network. I can reach it remotely and locally. Lights, August lock, Simplisafe alarm all work. However I noticed that the UNP IGD integration with the router can no longer see it. And I also noticed that the Nest integration option that had been there is now missing. I assume this means it wont see the Nest when I go to add the integration since it’s on a different docker network and the auto detected device integration dissappeared? Or should I try to add it manually and see what happens?
