Ended up rebooting a few more times and finally found my root cause in the logs:
Configuration error: Subscription misconfigured. Expected subscriber_id to match 'projects/./subscriptions/.
Corrected in my yaml and looks good!
Has anyone with a nest indoor cam got the sensors into HA? I only have the camera stream without motion sensors being picked up by the integration, it also doesn’t load every time. running on a pi4 with ssd.
Error opening stream rtsps://stream-eu1-bravo.dropcam.com:443/sdm_live_stream/CiQA2vuxrxN4u0F3TvAdQIikUgwaNiVGGwp8JtSLKrhEuyNati8ScQBMPhen7k7XBj-SxdcnHScukixw7JMRJM8BwsRDRLM8s7yf_qvWEoGxf7NHJ6Xj5Z29N5MYYZtjkJBrLZC834Ky0VlhVmrifahaG82_1sAMolwJwtikJjskkN1_GXR7sZCOAu7cixusJXAHZR0sAQRM?auth=g.0.eyJraWQiOiIyMzhiNTUxZmMyM2EyM2Y4M2E2ZTE3MmJjZTg0YmU3ZjgxMzAzMmM4IiwiYWxnIjoiUlMyNTYifQ.eyJzdWIiOiJuZXN0X2lkOm5lc3QtcGhvZW5peC1wcm9kOjg5NjU2ODUiLCJpc3MiOiJuZXN0LXNlY3VyaXR5LWF1dGhwcm94eSIsInBvbCI6IjNwLW9hdXRoLXNjb3BlLUFQSV9TRE1fU0VSVklDRS1jbGllbnQtMzQ4OTcxNTA0OTc4LWFsNHZ1djl1MmRuczE4bjdrMHRyOHJhM2JwaTByOWVhLmFwcHMuZ29vZ2xldXNlcmNvbnRlbnQuY29tIiwiZXhwIjoxNjExNTIyMDE4fQ.sZNWjgaNZ542z1edBnnP2ke3d89gqLPIKTcqoHt7QNKJ0mV7ssVXg9cxqlJ0FtDKAKkjZlw_kn4D01DCkZ7aWAddrXB3k09-6k_Vt2twSWZtY_3b7Q-tT8wZM1r35V62S3hSOgA3yn9zXPeUNNBXyA6fTTTmYBYHhYJtDPk-vrKlvu24OKA1s05ZHpWRA-wrzaDsqNpkjKtnV-mRJct2rkCIuhOQaAPIbG8DahkCwtIIXr8WuS3Njzj3NdtL5o5jviQX5Z7yvEzFnRIgyGOS81WI88bBvgPrmk0eRyszYeEfnsl7Q63xXggUDjd_mIdq7yQc6yv8YFDRVQdF685_7A
9:17:13 – Stream (ERROR) - message first occurred at 24 January 2021, 20:28:45 and shows up 523 times
method DESCRIBE failed: 403 Forbidden
9:17:13 – components/stream/worker.py (ERROR) - message first occurred at 24 January 2021, 20:28:45 and shows up 493 times
Request for https://homegraph.googleapis.com/v1/devices:reportStateAndNotification failed: 404
9:16:44 – Google Assistant (ERROR) - message first occurred at 24 January 2021, 20:59:16 and shows up 76 times
Error demuxing stream:
9:12:39 – Stream (ERROR) - message first occurred at 24 January 2021, 20:43:12 and shows up 79 times
The specified session has been invalidated for some reason.
8:23:29 – components/stream/worker.py (ERROR) - message first occurred at 5:31:36 and shows up 2 times
8:23:29 – components/stream/worker.py (ERROR) - message first occurred at 24 January 2021, 20:43:12 and shows up 5 times
Error demuxing stream while finding first packet: Invalid data - got 7 packets with missing DTS while initializing
8:06:36 – Stream (ERROR) - message first occurred at 6:45:00 and shows up 4 times
missing picture in access unit with size 10094
8:06:20 – components/stream/worker.py (ERROR) - message first occurred at 8:06:20 and shows up 3 times
nal size exceeds length: 9984 16
7:41:49 – components/stream/worker.py (ERROR) - message first occurred at 0:30:34 and shows up 2 times
Lots of errors appear also in the log. But the stream is working…
@Tim_Knowlden streams aren’t super solid yet due to the fact that urls expire after 5 minutes – working on a fix in https://github.com/home-assistant/core/issues/42793
Great, no problem. Keep up the good work!
I’ve just got a nest hello today and integrated. Is there a way to get the button press in as my only entity is the stream?
Sorry. Just saw this question. Yes. I did pay the fee.
It uses device automations and not a separate entity.
Thank you, just to work out now how to increase annoucement volume on Sonos
Hi there
I’m having the exact same problem, did you ever fix this?
I had the exact same problem and after restarting the Nest, deleting the integration and adding it again everything worked.
I was having the same exact issue and LL-HASS’s comment pointed me in the right direction. In configuration.yaml, the “subscriber_id” should be the subscription name, not topic name. Hope this helps anyone else that comes across this issue!
