Google Nest Hello Doorbell
Hi.
I have a Hello Doorbell which I have been trying to integrate into Home Assistant. Following the guide (in home assistant) on doing in this using Device Access Console seems to have set up everything but I am not seeing an entity. I’ve copied some info from my setup below …
My yams file has the following…
Can anyone offer some pointers as to where I may be going wrong please?
Many thanks
Cathy
Check out videos from @mostlychris .
I feel like I got lucky and it worked after I deleted EVERYTHING I did and followed the guides again.
It’s not easy, you’re not alone.
I know it’s frustrating but just delete it all and start again.
It took me about 20 mins to redo since I kind of knew the steps.
There might be newer info and I didn’t follow this, but usually videos help me more than guides.
Thanks. I’ll give that a go.
You are using the topic and not the subscriber id for your subscriber_id field in your configuration.yaml.
Thank you Chris. I’ll change that when I finish work today. I appreciate you letting me know.
All sorted now. Thank you both.
