Hello all!
I have HomeAssistant running in docker. (I also have remote access using duckdns and swag)
I recently bought a Google Nest Hub 2 and the Home Assistant automatically recognised it. I can cast my dashboard easily to it using the official google cast integration.
The dashboard is running live and i can see the changes for example if i switch of a light, etc…
I can use the touch sreen and I can open graph card to see the temperature details work as well.
My problem comes when i try to interract with buttons.
This is the error message what i can see:
Error message from HA Docker container:
2024-05-10 14:54:19.810 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139199196865728] Error handling message: extra keys not allowed @ data['return_response']. Got False (invalid_format) Home Assistant Cast from 192.168.0.237 (Mozilla/5.0 (Fuchsia) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 CrKey/1.56.500000)
Does anybody faced the same issue? Any suggestions?
Buttons work on my local network (PC, Phone, Tablet) and also work using remote access on my phone when i am not at home.
Thanks in advance!
Update:
I tried DashCast integration. With that it works. BUT:
With the Original Google Cast integration i can close the dashboard on the Nest Hub, open spotify for example, do whatever i want and open back the cast from the Nest Hub. With the Dash Cast if i close the cast I can’t go back to the dashboard. I have to go back to the HA and run the script for DashCast.
