Google Nest Hub dashboard issues
I have a Lovelace dashboard that I’ve been casting to a Nest Hub without issues for months. However recently it is only showing some of the elements. I’ve restarted both HA and the Nest Hub, but that does not fix it. Did something change to break that? Button and media entities work, sensor entities do not, nor do gauges and update entities.
It’s entities, not cards, because there are empty cards like this one:
          - type: custom:mushroom-climate-card
            entity: climate.hallway
            fill_container: true
            show_temperature_control: true
            collapsible_controls: true
            hvac_modes:
              - cool
              - heat_cool
              - 'off'
              - fan_only
              - heat
            tap_action:
              action: more-info
which do show up as a black square.
Can anyone check on their end if they can send a dashboard to a Nest Hub and see sensor, climate or gauge elements? (i.e. is this a me issue, or HA issue?)
I have the exact same problem… Seems like something have changed recently.
Thanks. Since it’s not just me I’ll log an issue.
Looks to be a known issue, and seems to be fixed in 2023.3: Casting Dashboard shows incomplete dashboard · Issue #88690 · home-assistant/core · GitHub
