I’ll had to change my Nest Hello doorbel, because to old one was falling apart .
So i’ll tried to integrate the new doorbel wintin the nest integration, but without any succes.
What i did:
Removed the integration, removed all the Cloud Project, OAuth Consent screen, OAuth Application Credentials settings en changed the Device Access Project .
And tried setting up everything as discribed
So i tried to troubleshoot this by the url:
And there it says:
So i tried to connect to https://my.home-assistant.io/redirect/oauth so i can troubleshoot what’s going wrong
and this is what’s happening
when i klic to "okay button
What to do next ? And is everything working when it’s configured as above ?
I already tried changing the Authorized redirect URIs within the Api console from https://my.home-assistant.io/redirect/oauth to the <HOME_ASSISTANT_URL>/auth/external/callback ,also tried both of them, but without any luck ( <HOME_ASSISTANT_URL> is then changed to my NabuCasa url )
* Error creating subscription: Failed to create subscriber 'projects/hassio-nest---------237/subscriptions/home-assistant-CHccmacN7O': 403 User not authorized to perform this action.
* Error creating subscription: Failed to create subscriber 'projects/---------203/subscriptions/home-assistant-MXzbcAQfOp': 403 User not authorized to perform this action.
* Error creating subscription: Failed to create subscriber 'projects/hassio-nest-------37/subscriptions/home-assistant-ANLQL5bxhV': 403 User not authorized to perform this action.
When deleting everything in HA and Google you can start from scratch. OR just have a look at what you are missing. The video is very clear in the steps to take or to check your own config what is missing.
i already start from scratch twice. Now getting this error over and over again
Error creating subscription: Failed to create subscriber 'projects/nest-hassio-365214/subscriptions/home-assistant-P9RJ7Hc6Fl': 403 User not authorized to perform this action.
Everything is just as discribed but somewhere there’s stil an issue
The mail adres is a personal mail address. This integration was working fine for months. But afther i had to change the doorbell i think i broke it.
Today i’ll start over again, step by step (after i removed everyting first)
Have an issue with this integration.
I did everything based on the documentation provided.
I can see that new devices found.
When I click it asks for the project id and MDM project ID, after that it opens a page for linking.
I see my oauth values, they are correct but redirecturl is always: redirect_uri=https://my.home-assistant.io/redirect/oauth
It’s not my domain.
For the Web application, i used my own domain but it never appears… so 2 days but mot lucky cant link account.
Had the same problem, my GCP is under a gsuite domain but Nest account was using a gmail. In my case the solve was to add my gmail address as an authorized user in GCP.
I personally gave up. I ordered an Ecobee Premium for one of my four AC units which I had to replace because the Nest failed causing the unit to run 24/7 burning out my condenser and air handler. While the Ecobee did require a developer account and the creation of an app profile, it required far fewer steps than the Nest and unlike the Nest, I actually got it to work with HA. I’m ordering three more Ecobees to replace my other three Nests so I can get those working with HA as well.
