I try to add the Google Nest integration in Home Assistant.
I do the whole procedure on this page: https://www.home-assistant.io/integrautions/nest/
It worked a few weeks ago, but it hasn’t been working for a while.
However, at one point I have an error: Timeout Resolving Oauth Token
It is to finalization.
Home Assistant is in a proxmox container.
It is possible that the concern has occurred since I passed on Proxmox, but I am more certain.
I have redone all the steps several times, but I still block at the same time: Timeout Resolving Oauth Token (the very last step).
My assistant home is up to date.
I also tested all the solutions I have found on the forum, but nothing works.
Do you have an idea ?
Thanks in advance
