Google Nest Integration Quota limit
I have the below google nest integration working but after refreshing the camera streams I always get a 429 error. I can see the cameras but then it times out with this warning and I think its related to the pub/sub quota limit but don’t know how to increate it.
@allenporter
I’ve also tried disabling ipv6 in HA network and this didn’t resolve it.
Any advice would be greatly appreciated.
Thanks,
Chris
Hi, please don’t ping people directly.
Upgrade your version of home assistant.
Apologies but as the creator of the integration, I assumed you may know best.
I’m running the latest already.
File an issue at following Help - Home Assistant if you think there is an issue (filling out the request information in the issue template). Thanks.
Is it not something setup wrong with the nest integration and not HA? I have other non Nest cameras that stream fine and its only the Nest ones via your integration that come up with that error.
