Hello, I have two Google Home Mini (one is the newer one, Nest) and I was trying to get them to say a message with TTS, unfortunately without success.
I have Home Assistant 0.103.6 running on Hassbian, SSL with DuckDNS and port 443 forwarded to 8123 in the router configuration. Moreover I don’t know if it is relevant but I have a PI Hole acting as DNS (and configured in the router as well)
I will write here the relevant piece of configuration.yaml and the log (in debug mode) that I get when I send a message “test” on my google nest mini:
http:
ssl_certificate: /home/homeassistant/dehydrated/certs/myname.duckdns.org/fullchain.pem
ssl_key: /home/homeassistant/dehydrated/certs/myname.duckdns.org/privkey.pem
base_url: myname.duckdns.org:9999
# Text to speech
tts:
- platform: google_translate
language: it
cache: true
cache_dir: /tmp/tts
time_memory: 300
base_url: https://192.168.178.83
service_name: google_say
and here is the log:
2020-01-12 22:32:47 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Received {'type': 'config/entity_registry/get', 'entity_id': 'media_player.mini', 'id': 25}
2020-01-12 22:32:47 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Sending {'id': 25, 'type': 'result', 'success': True, 'result': {'config_entry_id': '62218e923378479d83e1d08c50ee8ddc', 'device_id': 'a6e441cf06164903b1a61a528424678a', 'disabled_by': None, 'entity_id': 'media_player.mini', 'name': None, 'platform': 'cast'}}
2020-01-12 22:32:47 DEBUG (MainThread) [homeassistant.components.http.auth] Authenticated 91.64.213.16 for /api/history/period/2020-01-12T21:32:05.115Z using bearer token
2020-01-12 22:32:47 DEBUG (MainThread) [homeassistant.components.http.view] Serving /api/history/period/2020-01-12T21:32:05.115Z to 91.64.213.16 (auth: True)
2020-01-12 22:32:47 DEBUG (SyncWorker_13) [homeassistant.components.recorder.util] converting 0 rows to native objects took 0.015111s
2020-01-12 22:32:47 DEBUG (SyncWorker_13) [homeassistant.components.history] get_significant_states took 0.023418s
2020-01-12 22:32:47 DEBUG (SyncWorker_13) [homeassistant.components.history] getting 1 first datapoints took 0.000018s
2020-01-12 22:32:47 DEBUG (MainThread) [homeassistant.components.history] Extracted 0 states in 0.028901s
2020-01-12 22:32:55 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Received {'type': 'call_service', 'domain': 'tts', 'service': 'google_say', 'service_data': {'entity_id': 'media_player.mini', 'message': 'test'}, 'id': 26}
2020-01-12 22:32:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=tts, service=google_say, service_data=entity_id=media_player.mini, message=test>
2020-01-12 22:32:56 DEBUG (SyncWorker_2) [homeassistant.components.fritz.device_tracker] Scanning
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=media_player, service=play_media, service_data=media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_content_type=music, entity_id=['media_player.mini']>
2020-01-12 22:32:56 INFO (SyncWorker_8) [pychromecast.controllers] Not launching app CC1AD845 - already running
2020-01-12 22:32:56 DEBUG (SyncWorker_8) [pychromecast.socket_client] [Google Nest Mini:8009] Sending: Message urn:x-cast:com.google.cast.media from sender-0 to f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2: {'media': {'contentId': 'https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3', 'streamType': 'BUFFERED', 'contentType': 'music', 'metadata': {}}, 'type': 'LOAD', 'currentTime': 0, 'autoplay': True, 'customData': {}, 'requestId': 39, 'sessionId': 'f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2'}
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Sending {'id': 26, 'type': 'result', 'success': True, 'result': {'context': Context(user_id='b18a1f8784304395b524912bfea153c6', parent_id=None, id='10c8e4c3d732472fb2708fd037c52f5c')}}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.socket_client] [Google Nest Mini:8009] Received: Message urn:x-cast:com.google.cast.media from f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2 to *: {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 3, 'playbackRate': 1, 'playerState': 'IDLE', 'currentTime': 0, 'supportedMediaCommands': 274447, 'volume': {'level': 1, 'muted': False}, 'media': {'contentId': 'https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3', 'streamType': 'BUFFERED', 'contentType': 'music', 'metadata': {}}, 'currentItemId': 1, 'extendedStatus': {'playerState': 'LOADING', 'media': {'contentId': 'https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3', 'streamType': 'BUFFERED', 'contentType': 'music', 'metadata': {}}, 'mediaSessionId': 3}, 'repeatMode': 'REPEAT_OFF'}], 'requestId': 0}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.controllers] Media:Received status {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 3, 'playbackRate': 1, 'playerState': 'IDLE', 'currentTime': 0, 'supportedMediaCommands': 274447, 'volume': {'level': 1, 'muted': False}, 'media': {'contentId': 'https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3', 'streamType': 'BUFFERED', 'contentType': 'music', 'metadata': {}}, 'currentItemId': 1, 'extendedStatus': {'playerState': 'LOADING', 'media': {'contentId': 'https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3', 'streamType': 'BUFFERED', 'contentType': 'music', 'metadata': {}}, 'mediaSessionId': 3}, 'repeatMode': 'REPEAT_OFF'}], 'requestId': 0}
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/1e4e888ac66f8dd41e00c5a7ac36a32a9950d271_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:29:57.963498+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1629632944] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/1e4e888ac66f8dd41e00c5a7ac36a32a9950d271_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:29:57.963498+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>}
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/1e4e888ac66f8dd41e00c5a7ac36a32a9950d271_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:29:57.963498+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.socket_client] [Google Nest Mini:8009] Received: Message urn:x-cast:com.google.cast.media from f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2 to sender-0: {'requestId': 39, 'type': 'LOAD_FAILED', 'detailedErrorCode': 104, 'itemId': 1}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.socket_client] [Google Nest Mini:8009] Message unhandled: Message urn:x-cast:com.google.cast.media from f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2 to sender-0: {'requestId': 39, 'type': 'LOAD_FAILED', 'detailedErrorCode': 104, 'itemId': 1}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.socket_client] [Google Nest Mini:8009] Received: Message urn:x-cast:com.google.cast.media from f9135d3e-7c2e-4162-9ab2-2a9eaa6777d2 to *: {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 3, 'playbackRate': 1, 'playerState': 'IDLE', 'currentTime': 0, 'supportedMediaCommands': 274447, 'volume': {'level': 1, 'muted': False}, 'currentItemId': 1, 'idleReason': 'ERROR'}], 'requestId': 0}
2020-01-12 22:32:56 DEBUG (Thread-3) [pychromecast.controllers] Media:Received status {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 3, 'playbackRate': 1, 'playerState': 'IDLE', 'currentTime': 0, 'supportedMediaCommands': 274447, 'volume': {'level': 1, 'muted': False}, 'currentItemId': 1, 'idleReason': 'ERROR'}], 'requestId': 0}
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.366117+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1629632944] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.366117+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>}
2020-01-12 22:32:56 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1627850352] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=media_player.mini, old_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.264355+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>, new_state=<state media_player.mini=idle; volume_level=0.49000000953674316, is_volume_muted=False, media_content_id=https://192.168.178.83/api/tts_proxy/a94a8fe5ccb19ba61c4c0873d391e987982fbbd3_it_-_google_translate.mp3, media_position=0, media_position_updated_at=2020-01-12T21:32:56.366117+00:00, app_id=CC1AD845, app_name=Default Media Receiver, friendly_name=Google Nest Mini, supported_features=21391 @ 2020-01-12T21:29:52.238687+00:00>>}
What am I doing wrong? I tried the configuration without base_url on the tts, with base_url and explicit port 8123… what else could I try?
I really hope that somebody will be able to help me! Thanks in advance!
Dario
