Hello
I’ve purchase four Google Nest Minis Gen 2 for around the house. My goal is to have IoT things play a chime and TTS over each speaker at the same time. For example, when the LG washing machine has finished it’s cycle, then a chime will play along with the appropriate TTS (“Washing Cycle is Complete”). Currently when the wash cycle is complete, I’ve got a light bulb that flashes red for seven seconds and then remains on for 5 minutes. I’d like to add to that automation a chime and TTS that should play over the Google Nest Mini.
So, what is it I need to do to get the GNM to integrate with HA? I’m not planing on using Google Assistant to tell me the outside temperature or play music, but maybe the integration would be smoother if I did connect the mini to Google Home? It’s my understanding that the GNM needs to be on the same network as HA. So am I downloading Google Home onto my cell phone then powering up the Mini and configuring it that way? Am I installing the Google integration first on HA then powering up the Mini then moving on to configure it?
Thanks in advance for any help that can be provided.
