My garage doors are configured as “device_class: garage” which causes the pin to be required when opening. This is working fine.
I also have Envisalink setup for my DSC alarm panel. This is working in Home Assistant; however, when I try to control using voice - it asks for a PIN then appears to ignore the response. Instead it searches on my PIN (as if the conversation ended - and restarted).
I am currently using a different secure_devices_pin than the alarm_control_panel code; but, I did try making them match as well - same result.
One interesting note is that on my Google Home Hub (screen) - if I ask to arm the alarm on it - it displays a keypad on the screen, and if I type it in - it works as expected.
This leads me to believe the secure_devices_pin is working as expected, but something is off with the Google voice conversation or mappings.
Anyone else experiencing this? Saw other threads with voice issues, wondering if anyone else tried on a device with a screen to type in the PI.
Slightly different use case, but very similar behaviour…
I’ve had this intermittently for my Garage Door (exposed to Google Assistant via Nabu Casa) with a secure pin when using it on a Pixel 3.
In my use case it seems to be the result of a Play Services / Google App / Assistant update on the phone itself and typically a reboot fixes it immediately.
I base this conclusion on the fact that my wife typically has the same issue on her Pixel 3 within a few days of me, also resolved by rebooting the device.
Before my last post, I have already tried the next options and none of them worked for me:
Reboot my phone and Home Assistant
Uninstall google home and all updates of google assistant and install it again
Ask google to sync my devices
I experimented the issue for one week but finally it works again. I don’t know what happened, but now something I note different is that google now ask for a secure code and before it asked for a pin. Maybe it was an update of google
