OWG
(Dan L Adams)
October 26, 2022, 10:11am
1
First attempt at using the Google Sheets integration is generating this error:
The integration appears to be working as it is populating the headers in the Googlesheet :
… but no data. The ymal is below:
service: google_sheets.append_sheet
config_entry: b8071a942d422e1b2b68dc0c48b81688
worksheet: Heating
exterior_temp: {{(states('sensor.davis_vantage_pro_air_temp_outside') | float())}}
device: exterior_temp
The log derail (error) returns many lines of code and ends with this:
gspread.exceptions.APIError: {'code': 400, 'message': 'Invalid values[1][1]: struct_value {\n fields {\n key: "device"\n value {\n string_value: "exterior_temp"\n }\n }\n fields {\n key: "temperature"\n value {\n struct_value {\n fields {\n key: "[object Object]"\n value {\n null_value: NULL_VALUE\n }\n }\n }\n }\n }\n}\n', 'status': 'INVALID_ARGUMENT'}
Thoughts?
Hellis81
(Hellis81)
October 26, 2022, 12:05pm
2
It seems there is a indentation error. Exterior_temp is indented four steps. Not sure that is the issue, but then there is a template that is not enclosed in " ".
I also use sheets to long term save my heating.
I trigger on TRV temperature attribute and use this yaml in action:
- service: google_sheets.append_sheet
config_entry: 927e50ef6b3c6946d426cfd41c7d5de3
worksheet: >-
{{ (trigger.to_state.entity_id | replace("climate.", "")|
replace("_thermostat", ""))[0:5] | upper ~ (trigger.to_state.entity_id |
replace("climate.", "")| replace("_thermostat", "")|
replace("kok","kök"))[5:] }}
room_temp: >-
{{ state_attr(trigger.to_state.entity_id | replace("trv_", "") |
replace("_thermostat", "") | replace("kok", "vardagsrum"),
"current_temperature") }}
set_temp: >-
"temperature") }}
set_temp_TRV: "{{ trigger.to_state.attributes.temperature }}"
outside_temp: "{{ state_attr('weather.smhi_home', 'temperature') }}"
wind_speed: "{{ state_attr('weather.smhi_home', 'wind_speed') | float / 3.6 }}"
wind_bearing: "{{ state_attr('weather.smhi_home', 'wind_bearing') }}"
weather: "{{ states('weather.smhi_home') }}"
open_doors/windows: >-
{{ 'none' if expand('group.doors_and_windows') | selectattr('state',
'eq', 'on') | list | map(attribute='entity_id') | join(', ') == ''
else (expand('group.doors_and_windows') | selectattr('state', 'eq',
')).replace('binary_sensor.', '').replace('_', ' ') }}
Remember to make the automation queued since the write takes a few seconds to do.
OWG
(Dan L Adams)
October 26, 2022, 3:20pm
3
Thanks - Applied both suggestions and it works!
