Hey everyone, relatively new to Home Assistant.
I set up Google Tasks to show my family to do lists, that was easy to set up.
When I update the list outside of Home Assistant, the lists will not update on Home Assistant.
If I add a new item in tasks from Home Assistant, it updates the lists from the Google Tasks side, so seems to be pulling issue.
I tried to set up automation for To-Do lists to Get Lists or Update and added each Entity list, but it doesn’t pull anything consistently. I say consistently because every once in a while it updates a list (random list) but not sure how or when it does it. No errors in the automation, its running every 5 minutes but no luck.
Everything is up to date on versions for home assistant, features, etc.
Any suggestions would be helpful! Thank you
Automation items below:
