Hi everyone, my Google TTS stopped working suddenly and I can´t figure out whats broken.
Setup:
- Home Assistant Core as Docker Container (Home Assistant 2023.7.1, Frontend 20230705.1)
- 2x Google Nest Mini
Test Configuration:
service: tts.google_say
cache: false
entity_id: media_player.kuche
message: Das ist ein Test
language: de
Device status:
What´s happening:
I get the “Pling” noice from Google Nest, but no speech. Error messages in Log:
What have I tried:
Remove all devices, reinstall Services Google Assistant and Google Cast
Restarted all devices
Any idea, what´s broken here?
Logger: pychromecast.controllers
Source: /usr/local/lib/python3.11/site-packages/pychromecast/controllers/media.py:544
First occurred: 13:38:30 (1 occurrences)
Last logged: 13:38:30
Quick Play failed for http://172.17.0.3:8123/api/tts_proxy/baa76da175d3867ead8dff0d5c8ccd31125b8320_de_-_google_translate.mp3:audio/mpeg({})
Logger: homeassistant.helpers.script.websocket_api_script
Source: components/cast/media_player.py:730
websocket_api script: Error executing script. Unexpected error for call_service at pos 1:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 703, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 665, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1957, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 1997, in _execute_service
return await cast(
File "/usr/src/homeassistant/homeassistant/components/tts/legacy.py", line 147, in async_say_handle
await hass.services.async_call(
return await cast(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 235, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 845, in entity_service_call
response_data = task.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1192, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 889, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 730, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/pychromecast/quick_play.py", line 78, in quick_play
controller.quick_play(**data)
File "/usr/local/lib/python3.11/site-packages/pychromecast/controllers/media.py", line 547, in quick_play
raise PyChromecastError() # pylint: disable=broad-exception-raised
pychromecast.error.PyChromecastError
Logger: homeassistant.components.websocket_api.http.connection
Integration: Home Assistant WebSocket API (documentation, issues)
[140351512602960] Error handling message: Unknown error (unknown_error) julian from 192.168.200.20 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1823.67)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 26, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 680, in handle_execute_script
response = await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1569, in async_run
return await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
raise exception
return await cast(
return await cast(
return await coro
result = await task
