Google travel Time configuration in
I am trying to use below config for integrating Google travel time in my home assistant.
I get error while testing the yaml file.
- platform: google_travel_time
api_key: XXXX_XXXX
origin: “Trondheim, Norway”
destination: “Paris, France”
C:\Windows\system32>hass --script check_config
Testing configuration at C:\Users\ekaudhi\AppData\Roaming.homeassistant
←[31m2017-08-23 20:53:44 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping
values are not allowed here
in “C:\Users\ekaudhi\AppData\Roaming.homeassistant\configuration.yaml”, line
53, column 15←[0m
←[31m2017-08-23 20:53:44 ERROR (MainThread) [homeassistant.bootstrap] Error load
ing C:\Users\ekaudhi\AppData\Roaming.homeassistant\configuration.yaml: mapping
53, column 15←[0m
Can some let me know what is the error in my file.
Is it formatted like so:…
    api_key: XXXX_XXXXX_XXXXX
    origin: Trondheim, Norway
    destination: Paris, France
If it isn’t formatted as above yaml won’t like it note they are spaces not tabs.
Do you have other sensors?
Thanks it worked perfect.
:slight_smile: Glad to hear it :slight_smile:
@keithh666 I keep getting invalid config
Google maps travel times
    api_key: xxxxxxxxxxxx
    origin: xxxxxxxxxxxxxx
    destination: xxxxxxxxxxxxxxxx
What does the log say?
starting version 3.2.4 Testing configuration at /config ERROR:homeassistant.util.yaml:YAML file /config/configuration.yaml contains duplicate key "sensor". Check lines 62 and 69.
1:36 PM components/hassio/__init__.py (ERROR)
1:35 PM util/yaml.py (ERROR)
I also have a weather prediction sensor
So if you have them both in config.yaml, then you need to either use 1 sensor definition and group your sensors under it or name them sensor 1: and sensor 2: etc
Aha! I tried naming them sensor1 and sensor2. It needs a space!
Thank you
