teqqy
(Christian)
March 23, 2020, 10:33pm
1
my google_travel_time sensor works quite fine since some days ago.
- platform: google_travel_time
api_key: !secret ga_apikey
origin: zome.home
destination: zome.tim
Now the sensor detects my zone somewhere in the US but not in Germany where i live. The Map shows my zones correct. Are there errors in the 0.107 Version? I did not know it the error was on the latest 0.106.
Thanks.
jocnnor
(Jim O'Connor)
March 24, 2020, 6:01am
2
It looks like this bug
opened 06:52PM - 18 Mar 20 UTC
closed 01:14AM - 19 Mar 20 UTC
The problem
Location Updates via certain integrations stop working without using default_config: or manually specified zones:
Environment
Home Assistant release with the issue: 0.107.0
Last...
integration: zone
Which has already been fixed and merged as of 5 days ago. It should be in the next update.
In the meantime, replace your origin and destination with non-zone values if you need it to work right now.
teqqy
(Christian)
March 24, 2020, 8:21am
3
Ah. Thank you. At the moment this issue is less important for me, because i have to work from home. I can wait for the fix.
