Hi Team
Can some one give me a small hint…
Trying to setup a doorbell - got an Ikea switch (zigbee by zha) working. It activates an automation that calls a sonos script.
Works fine.
But, I can’t get sonos - google tts to say the new sentence -“some one by the door” It can only get it to say ‘Your husband coming home!’. I have been using the tts for a long time, when the windows opens. This works fine.
In the log I see this message:
Logger: homeassistant.components.tts
Source: components/tts/__init__.py:172
Integration: Text-to-Speech (TTS) ([documentation](https://www.home-assistant.io/integrations/tts), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+tts%22))
First occurred: 10:52:26 PM (3 occurrences)
Last logged: 11:16:41 PM
* Error on init TTS: No TTS from google_translate for 'Your husband coming home again!'
* Error on init TTS: No TTS from google_translate for 'Some one at the door'
I have read that adding baseURL solves this problem…
I have added this:
# Text to speech
tts:
- platform: google_translate
base_url: http://192.168.2.85:8123
Samme result.
Seems like, google tts is no longer working, and the ‘old’ stuff that works is because it is cached ?
Running latest HA.
System Health
Home Assistant Core Integration
version: 0.118.4
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.6
os_name: Linux
os_version: 5.4.77
arch: x86_64
timezone: Europe/Copenhagen
Home Assistant Cloud
logged_in: true
subscription_expiration: December 4, 2020, 1:00 AM
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: true
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
Hass.io
host_os: HassOS 4.17
update_channel: stable
supervisor_version: 2020.11.0
docker_version: 19.03.12
disk_total: 30.8 GB
disk_used: 17.1 GB
healthy: true
supported: true
board: ova
supervisor_api: ok
version_api: ok
installed_addons: ESPHome (1.15.3), Node-RED (7.2.11), Samba share (9.3.0), Visual Studio Code (2.9.0), Portainer (1.3.0), Mosquitto broker (5.1), InfluxDB (3.7.7), Grafana (5.3.1), chrony (1.1.2)
Lovelace
dashboards: 2
mode: storage
resources: 7
Looking forward for a hint - or to use some other tts ?
/Jorn
