Google TTS and SSL
Now, I know that there are other threads on this but none of them solved my problem.
I have just reinstated SSL certificates which I get on hassio from the DuckDNS add-on but I don’t use DuckDNS for anything else at the moment as I am not open to the Internet.
Google TTS has stopped working. Does anyone know how I can make it work again with SSL?
I have the following:
tts:
  - platform: google
    language: 'en-uk'
http:
  base_url: !secret base_url
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
In my secrets I have
base_url: https://192.168.1.25:8123
But I get the following errors when using Google TTS
Log Details (ERROR)
Sun Nov 18 2018 13:00:15 GMT+0000 (Greenwich Mean Time)
Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: SSLV3_ALERT_BAD_CERTIFICATE] sslv3 alert bad certificate (_ssl.c:841)
and
Log Details (ERROR)
Sun Nov 18 2018 13:00:14 GMT+0000 (Greenwich Mean Time)
Error doing job: SSL error errno:1 reason: SSLV3_ALERT_BAD_CERTIFICATE
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
I’m presuming it’s a letsencrypt certificate? If so the https request has to come via the named domain, you can’t use ip addresses.
I see, thanks.
Does that mean hassio with SSL running without any port forwarding cannot work with Google TTS?
I have removed it and TTS works so I suppose I will have to live without it.
Although it does seem to go against what we are ‘supposed’ to be doing.
No, but you’ll need some kind of dns on your network to translate the name to the ip address.
SSL is really only really beneficial for remote connections anyway, unless your internal setup is significantly different to others’ homes :slight_smile:
Ok, that’s fine, I kinda thought that but just had a paranoid moment.
Thanks for your help as always.
