Hi team,
well, my first ever automation worked today - HA turned my garden sprinkler off after the test period of 1 minute!! ( high fives self ) pushed it out to 10 minutes, then duplicated it for 1 hour on the orchard watering system. What a master!!
However… now that I’m playing with automations, I thought I’d have a go at TTS announcements from my google home. I have a front gate sensor, which tells me if the front gate is open or closed. Its a sensor, that works via command line. - The sensor works fine in the overview page - I can see the sensor change from False to True when the gate opens. - I can also monitor it via the dashboard, and have a widget that both changes colour and MDI when the gate opens. However, try as i might, i cannot get the google TTS to work.
Ive tried numerous syntax / format combinations, copying items from the docs, the community and youtube to no avail. Tried data_template, various combinations from other users…
here is the current automations.yaml
- id: '1541053054723'
alias: Veggie garden watering timer
- entity_id: switch.veggie_dripper
platform: state
to: 'on'
condition: []
- delay: 00:10
- alias: ''
service: switch.turn_off
- id: '1541057366386'
alias: Orchard watering timer
- entity_id: switch.orchard_dripper_
platform: state
to: 'on'
condition: []
- delay: 01:00
- data:
- id: '1541057939739'
alias: Front gate alert
- entity_id: sensor.gate_openclosed
platform: state
to: 'true'
condition: []
- service: tts.google_say
entity_id: media_player.kitchen_main_speaker
message: "The Front Gate has just been opened"
Some noob questions: - Does there need to be any other code in the config.yaml?
Does Google home ( in this case the kitchen main speaker ) need to be turned on first, via the automation in HA? - I note in the overview page, it is off, until I hit the power button to turn it to ‘Idle’…
thanks,
Jarrod.
