Google TTS Not Working
I’m a newbie in Home Assistant.
I Have a fresh install of HassBian running on a RaspBerry Pi 3. (HomeAssistant 0.54.0)
I added a google home media player in the configuration and tried via the webpage do have the Google Home say something.
You can see the call to the TTS (after a long delay) but the google home is not saying anything.
I added the IP address of the raspberry pi in HTTP Base URL in multiple formats:
Nothing seems to work.
I got voicerss working, but its just not the same, I really hope to get Google TTS working.
Home Assistant 0.54.0
Same problem here… not with google home but with a chromecast
I got mine working by assigning a fixed IP address to my raspberry pi and setup port forwarding
Same, but this is happening now with Automations that were previously working with Home and TTS. Seems like new GHome firmware may be stopping it in preperation for the “broadcast” feature announced on Oct 4th?
If I try to manually push it via services I hear the casting started “chime” sound but then no TTS output follows.
I just realized I never changed my HTTP url after I port forwarded 8123… All works fine now.
