When calling the google TTS service on my sonos media_players the service is called successfully and I can see the .mp3 file via the sonos app. BUT the sonos app presents an error saying ‘file not found’. I am running HA in a docker and on the host I can find the mp3 files created by the google tts service calls. They are located at ~/.homeassistant/tts/. I have ran a
sudo chmod -R 777 tts/
from the .homeassistant directory, restarted the docker and retested to assure it wasn’t a permission issue and got the same error. Anyone else experience this? Any fixes that can be recommended?
Hi, I’m having the same problem and I’m also running from docker. It seems that sonos can’t play the file because it has no permission to my homeassistant site. How can I give it access? On hhtp I’ve got the correct base_url set up. What can be wrong?? No errors on logs either. Please help me with this.
This is the error message I get from sonos when trying to play an mp3 when a google play service is called:
“the connection to xxxxxxx.synology.me was lost”
Translated: “xxx.mp3 file couldn’t be played. The connection with xxxx.synology.me was lost”
Any idea?? Thanks again.
