I currently have a Synology NAS (DS415+) and I want to be able to make some announcement (thought Google TTS) to a Bluetooth Speaker.
The best and easy way to handle this is using the vlc media_player component passing as a argument the alsa information related with the speaker, but because I didn’t find a easy way to install vlc in my NAS (from my previous experience, is a good practice try to avoid to tweak so much the system) I create a custom media_player component that can handle the tts.google_say service call.
In order to do this we need to:
- How to play a music file thought a Bluetooth Speaker
- Create a media_player component to be used in HA
- Configure HA
- How to Test and use it
1. How to play a Music File thought a Bluetooth Speaker
The easiest way to do this and avoid to tweak the NAS is using the existing tools.
Audio Station is a package that gives you the ability to play music files. It uses mplayer and pulseaudio, so we will use that in order to see how to play a file to a Bluetooth Speaker.
I had a usb bluetooth dongle installed on my NAS (Kinivo BTD-300 Bluetooth 3.0 Low Energy USB adapter https://kinivo.com/product/btd-300-usb-bluetooth-adapter-3-0) and of course a Bluetooth Speaker (a old Jawbone Jambox).
We must:
Pair the bluetooth speaker to the NAS, to do that just follow this tutorial https://www.synology.com/en-global/knowledgebase/DSM/help/DSM/AdminCenter/connection_bluetooth.
Play a music file through the Bluetooth Speaker, to do that just follow this tutorial https://www.synology.com/en-global/knowledgebase/DSM/help/AudioStation/audiosource).
While the music file is playing, open a ssh shell to the NAS and check the processes that belongs to the AudioStation user:
admin@DiskStation:/tmp$ ps ax -l | grep AudioStation
0 S 1024 18468 15503 0 80 0 - 5780 pipe_w pts/21 0:00 grep --color=auto AudioStation
5 S 254178 19776 1 0 75 -5 - 164993 ? ? 46:43 /var/packages/AudioStation/target/sbin/synoaudiod
5 S 0 19920 1 0 69 -11 - 60270 SyS_pp ? 0:27 /var/packages/AudioStation/target/bin/pulseaudio --realtime=false
5 S 254178 20528 1 0 75 -5 - 9403 ? ? 13:26 /var/packages/AudioStation/target/sbin/synorcd
5 S 254178 32348 1 0 75 -5 - 61262 ? ? 0:03 /var/packages/AudioStation/target/bin/mplayer -gapless-audio -ao pulse::bluez_sink.00_21_3C_6D_37_01 -srate 44100 -channels 2 -format s16le -unique bluez_sink.00_21_3C_6D_37_01 -daemon /volume1/music/Text.mp3 -volume 67
So we can see the command line to do that is:
Where pulse::bluez_sink.00_21_3C_6D_37_01 is the ID of the bluetooth speaker (pulseaudio), this is important for the next step.
Let’s create a shellscript to handle that. Is important to consider that:
The tts.google_say service call will request to the media_player component to play a mp3 file (a URL)
The mplayer installed with Audio Station does not support TLS/SSL, the script will download first the file and then play the local mp3 file
The mplayer command needs to be executed with sudo in order to work (I didn’t find a way to avoid this).
I named the script play_url_bluetooth.sh and put it on the folder /config/programs:
2. Create a media_player component to be used in HA
I created a very simple media_player component that was named bluetooth_speaker and use the previous play_url_bluetooth.sh script:
I named the component bluetooth_speaker.py and put it on the folder /config/custom_components/media_player:
3. Configure HA
3.1 Enable https on HA (Optional but recommended)
To enable SSL Access to your HA, is necessary to add the following to configuration.yaml:
http:
# Uncomment this to add a password (recommended!)
api_password: YOUR_PASSWORD
ssl_certificate: PATH_TO_YOUR_SSL_CERTIFICATE
ssl_key: PATH_TO_YOUR_SSL_KEY
# Uncomment this if you are using SSL or running in Docker etc
base_url: WWW.YOUR_DOMAIN.COM:8123
3.2 Configure Google TTS
We must add the following to the configuration.yaml:
tts:
platform: google
cache: true
time_memory: 300
language: 'en'
Notice: Is important to have external access to HA in order that the TTS service works, so in this case is necessary to create a port-forwarding rule for 8123.
3.3 Configure the bluetooth_speaker component
Just add to configuration.yaml:
media_player:
platform: bluetooth_speaker
3.4 Run HA
After run HA, you will see the new media_player component named Bluetooth Speaker:
4. How to Test and use it
4.1 Using HA States GUI
Click in the “…”
Write some text and test it:
4.2 Using the Development Tools on HA GUI
Click on the “Services” icon on Development Tools Section, and make a service call like this:
4.3 Make a Call from a Script
Inside a script, you can use the tts.google_say service like this:
service: tts.google_say
entity_id: media_player.bluetooth_speaker
message: 'Testing Google Say TTS Service'
language: 'en'
