I have automations trigger tts.google_translate_say with an entity ID of a speaker (or speaker group) and a message.
The .mp3 file is generated successfully in the tts folder, but my Google home devices make a sound like they’re about to say something (e.g. play the mp3 file from the tts folder) but it never actually plays now.
It just makes the noise like it’s about to then nothing.
I’m also having issues with TTS. I added both my internal_url and external url (http://xxx.xxx.xxx:8123 and https://xxxx.duckdsn.org:8123) and finally added the base_url: http://xxx.xxx.xxx:8123 under tts in my configuration file. But when I try to play a notification that uses the tts, no voice is heard other than the bleep the Google Home Mini gives.
Did you do anything else?
EDIT: Hmm, so maybe this (in my case), was a matter of xx amount of reboots.
Finally both TTS and Cast started to work again with the below configuration:
