hildwin
(Frank Bergmann)
April 16, 2017, 2:36pm
1
I’m not able to play anything via Google tts with a Squeezebox or a Volumio media player.
Here my code from configuration.yaml
http:
api_password: PWD
ssl_certificate: /etc/letsencrypt/live/URL.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/URL.duckdns.org/privkey.pem
base_url: URL.duckdns.org
trusted_networks:
- 192.168.178.0/24
- 127.0.0.1
- ::1
media_player:
- platform: squeezebox
host: 192.168.178.250
port: 9001
- platform: volumio
host: 192.168.178.41
port: 3000
I try to play tts via the frontend. The MP3-files are build correctly and located in
/home/homeassistant/.homeassistant/tts/
I can play them via https://URL.duckdns.org/api/tts_proxy/SOMENUMBERS_google.mp3
Is the configuration correct? Which type of media players are able to play tts?
Any idea or suggestion? Thanks in advance! I’m running 0.42.3.
got same problems… this is a mismatch of the certs between your hass instanz and the volumio
I have the same issue here. TTS-files play from my browser, but not in Volumio.
It’s clear that it has something to do with CURL and certificates…
I’ve asked a question at the Volumio forum:
https://volumio.org/forum/certificate-verification-failed-t7794.html
I solved this issue, here are the steps you must follow:
SSH into your Volumio server
Type:
openssl s_client -connect xxxxx.com:443 |tee logfile
Copy the server certificate. (From ‘-----BEGIN CERTIFICATE-----’ to ‘-----END CERTIFICATE-----’).
Type quit and press enter. Then go to the directory in which the certificates are stored:
cd /etc/ssl/certs
Open the certificates store:
sudo nano ca-certificates.crt
Paste the certificate at the bottom of the file. Save the file, and see if it worked. It did for me !
Niklas
(Niklas)
October 15, 2017, 8:05pm
5
My setup also doesn’t work, even though I’m not even using any kind of encryption yet.
NEwest Version of both HA and Volumio. What else could be the problem? Playing back the generated files inside the browser is no problem at all.
Would be great if someone could help me out!
Thanks a lot
