Google TV Steamer - Border Router
Been working on this all day and getting nowhere, suspect I’m doing something wrong.
I’m wanting to setup a Google TV Streamer as a second border router as a way of extending the range of the network. I can see the device when viewing the thread config:
How do I get it to join the ha-thread-46f6 network?
What I think is wrong is I don’t think I have ever setup the streamer as a matter/thread device, I purchased it some time ago and have since then duped the box. As a result, I don’t have a QR code and the device itself doesn’t have a QR or join code on it. if that is what I need doesnt anyone know if I can get around this. Or is there another setup I’m missing?
fwiw I did setup the streamer with Google Home on the same andriod device as I have the companion app on, however that setup as far as I can see didnt include any Matter setup.
Side note, I have no idea what the NEST-PAN-9B48 network is :slight_smile:
Keep in mind that all Thread devices are not Matter devices. Thread is just for a device’s connectivity, analogous to WiFi. Matter can be used for device control. Some, but not all, Thread Border Routers are also Matter Controllers, so while they “speak” Matter they don’t have any QR to join another fabric as they form a new fabric themselves.
The HA screen you captured shows any TBRs that have been detected on your network. If HA has saved the network’s security credentials, it displays the circled (i). The NEST network has no border routers anymore but must have been detected and its credentials saved in HA previously. If you no longer have that network or need those credentials, you can delete them. Unfortunately, they may still be saved on your phone e.g. via Google Play services.
If you want your Google streamer to join your OTBR thread mesh, it needs to have the same credentials as that mesh. Unfortunately I’m not aware of any UI that permits you to set or change the Thread credentials of a Google TBR. It kind of just picks them for you when you set it up. Sometimes, if the phone you’re using for setup already has credentials saved via the Google Play services, it will pick those.
So one approach could be to erase the Google Play data, sync the OTBR credentials to your phone so they’re the only ones there, factory reset the streamer, and use that same synced phone to set up the streamer again, hoping it pulls the HA credentials instead of creating new ones. If you try this and it works, let us know!
In general the tools for Thread management are kind of a mess right now, at least from a UX perspective, in particular if trying to combine different vendors. Since Google (and others) don’t let you set credentials, it’s often easier to set your OTBR to use their credentials, rather than the other way around. Hopefully these UIs improve.
All that said, you mentioned wanting to extend your network, and adding a second TBR is not really the best way to go about that — Thread repeater (router) nodes are preferable, similar to how Zigbee and Z-wave work. Adding TBRs does add some resilience, but too many can actually make things worse. You can even make your own repeater Thread node using a esp32-h2 for around $5.
Thank you so much @peterxian for your detailed reply. I’ve been using zigbee for some time and it just seems to work (well most of the time), crazy how we are in an immaturity situation with Matter where we need to cross our fingers that a TBR joins the correct fabric.
But your correct, my desire is to extend and strengthen the range of the network in the same way as I’ve done with my zigbee mesh through multiple Sonoff’s flashed as zigbee routers. I’ll look into the esp32-h2, sounds like it’s exactly what I need! It does however seem a bit of a pain flashing them, are you aware if any web flashers have been created yet similar to darkxst Sonoff ZBDongle-E flasher?
Thx!
