Could someone please post their config for Google Wifi / OnHub?
(Is it even worth adding this? Does it provide useful info?)
Iâll post mine in a few hours - Iâm stuck at work!
I group my Google wifi info with a few items from speedtest.net - this then shows me that everything is up and running and current internet speed. Itâs a good general kind of âcheckâ to see if the infrastructure needs attention or if itâs my kids downloading all the internets again.
Ok:
sensor googlewifi:
- platform: google_wifi
#SPEEDTEST
sensor speedtest:
platform: speedtest
minute: 30
hour:
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 14
- 16
- 18
- 20
- 22
monitored_conditions:
- ping
- download
- upload
and the group:
Internet:
- sensor.speedtest_download
- sensor.speedtest_upload
- sensor.speedtest_ping
- sensor.hass_uptime
- sensor.google_wifi_status
- sensor.google_wifi_uptime
- sensor.google_wifi_last_restart
- sensor.google_wifi_current_version
- sensor.google_wifi_local_ip
- sensor.google_wifi_new_version
Gives you :
Thanks for posting that, brendanheyu, but it doesnât work for me at all.
I must be missing somethingâŚ
I thought maybe I needed to specify the host/IP but Iâm not sure exactly how thatâs supposed to look. The example config doesnât show it (which is why I asked to have someone post theirs here). When that didnât help I just added it as follows:
sensor googlewifi: - platform: google_wifi host: 10.88.7.1
After a restart, that left home-assistant unreachable.
WHY does this have to be so DIFFICULT?!
because your formatting is incorrect. âhostâ cannot be on the same âlevelâ as - platform
You should ALWAYS verify the config is correct before restarting.
I fail to see the level of difficulty you are seeing. It is a pretty simple layout. Devices go into config, system reads config, system displays/controls devices/device info.
I DID verify the config. It returned no errors.
Where is it documented that âhostâ cannot be on the same âlevelâ as â- platformâ? How is a newbie supposed to know that? What is the correct formatting? And where is that documented?
Itâs the yaml formatting. Has nothing to do with Home Assistant
As for failing to see the difficulty, maybe try to see it from my point of viewâŚ
Iâm a tech-savvy guy, trying to get just ONE simple, little thing to work in hass.
I go to the docs and copy/paste the example config into my configuration.yaml
That doesnât work.
I ask for someone to post their config and brendanheyu is nice enough to do so.
That doesnât work, either.
I try to modify it as best I can using the information provided in the docs (which DONâT tell me where to place or how to format any of the options listed).
That renders my system unreachable.
And when I reach out for help, I canât seem to get answers to the most important questions Iâm asking. Could somebody please just say, âHey, Donnie, hereâs what I think youâre missing. Have a look at this [link].â
You really fail to see the difficulty Iâm having?! I get that youâve been doing it for long enough that itâs not difficult for you, but this is the most noob-UNfriendly program Iâve ever dealt with!
Thanks for posting that, silvrr. Iâm now more confused than ever. If you would try to answer the following questions (which are not answered by the linked page â or if they are, itâs not clear to me), Iâd really appreciate it.
- Why do some items start with a dash and others donât? Even when they are (or appear to be if youâre a noobie) the same thing? I.e. â - platformâ (as shown in brendanheyuâs post) and â platformâ as shown in the example on the YAML page you linked?
- I think I get that a dash indicates that something is an item in a collection but why is âplatformâ sometimes an item in a collection and sometimes not?
- In the third example given on the YAML page:
sensor: - platform: mqtt state_topic: sensor/topic - platform: mqtt state_topic: sensor2/topic
Why is it not:
sensor: - platform: mqtt state_topic: sensor/topic state_topic: sensor2/topic
or:
or:
sensor: platform: mqtt state_topic: sensor/topic platform: mqtt state_topic: sensor2/topic
How am I supposed to know/understand the differences between those variations and whatâs right/wrong?
NOTE: I just edited the above code blocks. I do understand the two space indentation - itâs the forum markup that Iâm struggling with.
Home Assistant isnât really ready for Joe User yet. This has been a topic of discussion for quite some time. You are required to learn a few things in order to use it. Or use a different product. Or wait to use it.
Iâm sorry, I donât see anything that you could be missing, unless you have errors in your configuration (not related to the Google Wifi) that are causing it to stop parsing your config. If you want help, the best thing is to post your configuration.yaml in its entirety minus your secret credentials.
because each instance is a NEW sensor. You canât have multiple state_topics for a single sensor.
Thatâs all yaml and itâs format. Yaml is like XML or HTML. Itâs a format for text. Yaml has the advantage of being âmore human readableâ than XML or HTML.
Yaml is 100% dependent on spacing, by this i mean the number of spaces for each indent:
top_node:
first_indent:
second_indent:
third_indent:
- my
- list
- of
- multiple
- items
Ok, so this is weather you have multiple items or just one. For example, this is a typical automation with 1 trigger:
platform: state
entity_id: sensor.mysensor
What if you wanted more triggers? Well youâd need to specify a list of triggers. The the problem is that yaml doesnât understand when an item starts and stops because yaml is indent formatted.
- platform: state # FIRST ITEM START
entity_id: sensor.mysensor # PART OF FIRST ITEM
- platform: time # SECOND ITEM START
etc... # PART OF SECOND ITEM
These dashes can be anywhere and they typically mean âa list of itemsâ.
This is people being lazy or not understanding when itâs needed. Personally, I always use the dash. Itâs only not needed when you only have 1 item.
Because the component was built to only handle 1 state topic. If you want more than one, you make more than one mqtt platform. This was done by design, itâs doesnât have anything to do with yaml.
The config checker looks at the shape of the yaml. Iâm not sure it actually verifies that the configuration itself is correct. This is what you are running into.
First off, THANK YOU SO MUCH for this!!! Finally, I feel like Iâm starting to comprehend.
UGH! Not to me! Iâll take XML over this any day!
OK. I do get that part but your example is still helpful.
Ah ha! Now Iâm starting to understand!
So, based on what I was trying to do, this would be correct?
sensor googlewifi: platform: google_wifi host: 10.88.7.1
Close, the platform: googlewifi needs to be placed inside the sensor section. The sensor section does not take any extra keywords. Yaml doesnât accept spaces in section names either.
host: 10.88.7.1
So if you look at the documentation you see this:
Everything you see there is a line item that will occur at the same indentation level as the platform: host, name, and monitored_conditions. monitored_condtions accepts an array of information that you may want. So a fully made config would look like this:
host: 10.88.7.1
name: My Google Wifi
- 'current_version'
- 'new_version'
- 'uptime'
- 'last_restart'
- 'local_ip'
- 'status'
But if you want everything, you donât need to specify the monitored_conditions at all.
Host, Name, and Monitored Conditions are all OPTIONAL which means that they do not need to be specified for it to work.
What, in that documentation, tells me that? How am I supposed to know that without having you tell me? (Which I very much appreciate, BTW, but it would be nice to be self-sufficient! )
Wait⌠so the dash doesnât indicate an indentation level?
top_node: - first_indent still_first_indent second_indent
??? or:
or:
top_node: - first_indent second_indent
And yet, it does not work!
Iâll post my configuration.
Like I said before, it could be something else in your configuration.yaml that is messed up that prevents it from processing.
Wait â but this works for brendanheyuâŚ?
