I made it!
These little Smart-Sockets from gosund are really cheap and working fine.
Bad thing is: they cannot be flashed OTA with different firmware like ESPhome/Tasmota without opening and they work only with the Smart-Life app, so internet is always needed.
For flashing with ESPhome they have to be opened.
See here for how to open the gosund-plug for flashing.
to open the plug case i used a lathe wich worked fine without a damage!
Then i connected my USB-Flasher and flashed a blank esphome bin file.
So OTA was enabled.
After some trying with the gpios i got a running well ESPhome-Plug.
I then calibrateted voltage and current with a 2000W Heater and now the firmware is ready, also for you:
substitutions:
plug_name: gosund_plug_1
# Higher value gives lower watt readout
current_res: "0.00221" # geeicht mit 2000W Heizlüfter
# Lower value gives lower voltage readout
voltage_div: "733"
esphome:
platform: ESP8266
board: esp8285
wifi:
networks:
- ssid: "--------"
password: ""--------""
- ssid: ""--------2""
- ssid: ""--------"3"
manual_ip:
static_ip: 192.168.3.10
gateway: 192.168.2.1
subnet: 255.255.252.0
captive_portal:
logger:
api:
ota:
# Enable Web server
web_server:
port: 80
time:
- platform: homeassistant
binary_sensor:
# Binary sensor for the button press
- platform: gpio
pin:
number: GPIO13
inverted: true
on_press:
- switch.toggle: relay
switch:
- platform: gpio
restore_mode: ALWAYS_OFF
pin: GPIO15
on_turn_on:
- light.turn_on: led
on_turn_off:
- light.turn_off: led
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO04
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
change_mode_every: 8
update_interval: 5s
- platform: total_daily_energy
name: "${plug_name}_Total Daily Energy"
power_id: "${plug_name}_Wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
- platform: uptime
- platform: wifi_signal
update_interval: 60s
text_sensor:
- platform: wifi_info
ip_address:
ssid:
output:
# blue LED
- platform: esp8266_pwm
pin:
number: GPIO02
inverted: true
light:
# Relay state light
- platform: monochromatic
output: state_led
# green LED
status_led:
pin:
number: GPIO00
inverted: true
i used the code from here but this code is for a different type of plug but gave me a good startpoint.
I added WiFi IP and SSID as sensor.
So now the first Gosund Plug is ready to use in a local network without using any cloud!
Have fun!
