Is it possible to integrate these plugs in Home Assistant?
I can’t connect them via Tuya unfortunately, because Tuya-convert doesn’t work anymore on the EP2 Plugs
Tuya normal or tuya-local should work, there are multiple posts around this one which I will not repeat…try searching
EDIT: most of these no longer have ESP chip so converting seems to have hit a dead-end
