I’m trying to install home assistant on my old synology NAS DS212j
so far I only get “404: Not found” on localhost:8123
here’s what I did, and hope any can help me out.
I followed every step on this page
https://home-assistant.io/docs/installation/synology/
since I cannot use docker, I go through method 2 without any problem
until the last part, I didn’t copy any “configuration.yaml”
but tried to start home assistant with this:
$ sudo /volume1/homeassistant/hass-daemon start
It failed and said permission deny, so I went back to my DSM control panel and set the homeassistant folder’s permission for user “homeassistant” to “read/write”
after this I was able to start with: $ sudo /volume1/homeassistant/hass-daemon start
but could not connect to http://192.168.0.1XX:8123 at all
Then I tried to copy a simple yaml file to the homeassistant folder, then restart homeassistant, then I get the “404: Not found”. (the yaml I have is below).
anyone know what I can do next?
I’m stuck with no clue…@@
Thank!
my configuration.yaml---------------
homeassistant:
latitude: 22.5083333
longitude: 120.2416667
elevation: 25
unit_system: metric
time_zone: Asia/Taipei
http:
api_password: 123456789
group: !include groups.yaml
