Hello HA community,
since two days I have a HA core installation 2024.10.2 with Bookworm on a RPi4 and I am quite happy to have made it this far.
Now I have two challenges that I have not yet overcome - please have mercy on the beginner questions:
the first step to linking e.g. with a Shelly Plug S should probably be to add an integration. When I do exactly this, I get an error:
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
It doesn’t matter which integration I select. There are plenty of threads about this, but I haven’t found a good solution yet. Do you have any tips? -
i thought HA finds manageable devices mostly on its own. This seems to fail because I am running a segmented network and the devices in question are not in the same segment as the HA-RPi. However, the segments with the devices are accessible via the default gateway. How do I explain to the HA that it should search in other segments?
Thanks and best regards,
Boris
